Model.hm_morph_getmvoledge#
Model.hm_morph_getmvoledge(node1, node2)#
Returns the morph volume edge ID for the specified nodes along the edge.
Parameters:
  • node1 (Entity) – The object describing the node entity of the first node on the edge.
  • node2 (Entity) – The object describing the node entity of the second node on the edge.
Returns:
Example#
Find the edge run through nodes with IDs 5 and 8#
import hm
import hm.entities as ent
model = hm.Model()
_,result = model.hm_morph_getmvoledge(node1=ent.Node(model, 5), node2=ent.Node(model, 8))
print("edgeID",result.edgeID)
