Model.hm_getmidsurfaceinfo#
- Model.hm_getmidsurfaceinfo(query_type, input_collection, output_entity_type=hm.entities.Surface)#
Returns information related to geometric midsurfaces.
- Parameters:
query_type (hwString) –
The type of query to perform:
find_midsurface - Finds midsurfaces corresponding to
input_collectioncomponents, surfaces or solids. The return is the list of output_entity_type IDs.find_parent_geometry - Finds components, surfaces or solids corresponding to
input_collectionmidsurfaces. The return is the list ofoutput_entity_typeIDs.is_midsurface - Checks if a given
input_collectionof components or surfaces consists of midsurfaces only, non-midsurfaces only, or both. The return is yes, no, or mixed.input_collection (Collection) – The collection containing the entities. Valid entities are defined by
query_type.output_entity_type (EntityFullType) – The type of output entity. Valid values are defined by
query_type. If there is only one possible value, this can be omitted.
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:Keys valid for
query_type="find_midsurface":midsurface_entities (list) - List of midsurface entities.
Keys valid for
query_type="find_parent_geometry":parent_geometry_entities (list) - List of parent geometry entities.
Keys valid for
query_type="is_midsurface":is_midsurface (hwString) - Indicates if the input entity is a midsurface (yes), not a midsurface (no), or mixed (mixed).
Examples#
Get the list of middle surfaces correspond to solid with ID 19#import hm import hm.entities as ent model = hm.Model() solids = hm.Collection(model, ent.Solid, [19]) _, result = model.hm_getmidsurfaceinfo( query_type="find_midsurface", input_collection=solids ) print("midsurface IDs: ", [ surf.id for surf in result.midsurface_entities])
Get the component containing the original geometry for the middle surface with ID 19#import hm import hm.entities as ent model = hm.Model() surfs = hm.Collection(model, ent.Surface, [19]) _, result = model.hm_getmidsurfaceinfo( query_type="find_parent_geometry", input_collection=surfs, output_entity_type=ent.Component ) print("parent geometry component IDs: ", [ comp.id for comp in result.parent_geometry_entities])
Check if the surface with ID 19 is a midsurface#import hm import hm.entities as ent model = hm.Model() surfs = hm.Collection(model, ent.Surface, [19]) _, result = model.hm_getmidsurfaceinfo( query_type="is_midsurface", input_collection=surfs ) print("Midsurface check for surface ID 19: ", result.is_midsurface)
