Model.setqualitythresholdcolor#
- Model.setqualitythresholdcolor(range_id, color)#
Sets the color for a specified element quality index range. This function is related to the element quality view mode.
- Parameters:
range_id (int) –
Specifies the element quality index range to update. Valid values are:
0 - Ideal (ideal ≤ QI < good)
1 - Good (good ≤ QI < warn)
2 - Warn (warn ≤ QI < fail)
3 - Fail (fail ≤ QI < worst)
4 - Worst (worst ≤ QI)
color (int) – The color to use. Valid values are 1 through 64.
Example#
Sets the color for “Good” elements to blue#import hm import hm.entities as ent model = hm.Model() model.setqualitythresholdcolor(range_id=1, color=9)
