Model.surfacespherefromfournodes#
- Model.surfacespherefromfournodes(entitylist)#
Creates a sphere which passes through the four specified nodes, and optionally, prepares it for immediate use within the automesher. It can also identify a region in the shape of such a sphere for the automesher to use under the mesh without surface option.
- Parameters:
entitylist (EntityList) – The list of the four nodes entities through which the surface will pass.
Example#
Create a sphere which passes through nodes with IDs 1 , 2 , 3 , and 4 , but not create any elements on the sphere#import hm import hm.entities as ent model = hm.Model() model.surfacemode(mode=4) model.surfacespherefromfournodes( entitylist=[ ent.Node(model, 1), ent.Node(model, 2), ent.Node(model, 3), ent.Node(model, 4), ] )
Note
The model.surfacemode(mode=4) directive tells HyperMesh not to pass the information on to the automesher for element creation.
