Model.hm_attributelist#
Model.hm_attributelist(entity_type, entity_id, value)#
Returns a list of all attribute IDs or names assigned to a specific entity for the current template.
Parameters:
  • entity_type (EntityFullType) – The type of entity to query.
  • entity_id (unsigned int) – The ID of the entity.
  • value (hwString) –
    The type of list to return. Valid values are:
    id - List with attribute IDs.
    name - List with attribute names.
Returns:
  • hwReturnStatus - Status object
  • HmQueryResult - Result object containing the output values:
    • Keys valid for value="id"
      • value (numpy.ndarray)
    • Keys valid for value="name"
      • value (list of strings)
Examples#
List the attribute IDs for the current template assigned to material with ID 6#
import hm
import hm.entities as ent
model = hm.Model()
_, result = model.hm_attributelist(entity_type=ent.Material, entity_id=6, value="id")
print("value", result.value)
List the attribute names for the current template assigned to material with ID 6#
import hm
model = hm.Model()
_, result = model.hm_attributelist(entity_type=ent.Material, entity_id=6, value="name")
