Model.penetrationrecheck#
Model.penetrationrecheck(collection, reduction, scale, display_mode, normal_scale, label, segment, magnitude_mode)#
Modifies the element thickness to correct penetration problems.
Parameters:
  • collection (Collection) – The collection containing the entities to be modified.
  • reduction (double) – The average thickness reduction.
  • scale (double) – The thickness scale factor.
  • display_mode (int) –
    The type of entity to be displayed.
    0 - Nodes
    1 - Normals
    2 - Contour
  • normal_scale (double) – The magnitude percentage or the uniform size.
  • label (int) –
    The label vector option.
    0 - Vector labels off
    1 - Vector labels on
  • segment (int) –
    The segment orientation option.
    0 - Elements normal will not be considered
    1 - Elements normal will be considered
  • magnitude_mode (int) –
    Determines if a magnitude percentage or a uniform size is to be used.
    0 - Uniform size
    1 - Magnitude percentage
Example#
Modify the element thickness#
import hm
import hm.entities as ent
model = hm.Model()
# Creating the collection that contains the elements from the group named "E2E"
filter = hm.FilterByCollection(ent.Element, ent.Group)
groups_collection = hm.Collection(model, ent.Group, "name=E2E")
elements_collection = hm.Collection(model, filter, groups_collection)
model.penetrationrecheck(
    collection=elements_collection,
    reduction=0,
    scale=1.0,
    display_mode=0,
    normal_scale=1.0,
    label=1,
    segment=1,
    magnitude_mode=1,
Note
templatefileset() is required.
