Model.nodemarkbypath#
Model.nodemarkbypath(node_entity1, node_entity2, collection)#
Creates a node path from the starting node to the ending node. If both node_entity1 and node_entity2 lie on free edges, the path will follow free edges where possible. Otherwise, the shortest path is returned.
Parameters:
  • node_entity1 (Entity) – The object describing the first node entity.
  • node_entity2 (Entity) – The object describing the second node entity.
  • collection (Collection) – The collection containing the node entities to populate.
Example#
Determine the path between the nodes with IDs 100 and 110#
import hm
import hm.entities as ent
model = hm.Model()
outcollection=hm.Collection(model, ent.Node, populate=False)
model.nodemarkbypath(
    node_entity1=ent.Node(model, 100),
    node_entity2=ent.Node(model, 110),
    collection=outcollection,
