Model.modelcheck_createchecks#
- Model.modelcheck_createchecks(filename, add)#
Loads a model check config file and creates check and correction entities.
- Parameters:
filename (hwString) – The full path and file name of the config file to load.
add (int) –
0 - Only the checks in the new config file will be loaded (default).
1 - The config file is appended onto the existing checks.
Examples#
Load the config file “C:/temp/my_checks.xml”#import hm import hm.entities as ent model = hm.Model() model.modelcheck_createchecks(filename="C:/temp/my_checks.xml", add=0)
Append the config file “C:/temp/my_checks.xml”#import hm import hm.entities as ent model = hm.Model() model.modelcheck_createchecks(filename="C:/temp/my_checks.xml", add=1)
