Model.splitelementbyelemselect#
- Model.splitelementbyelemselect(elem_collection, consider1ds=1, dividequadsoptions='none', midpointoptions='none', reverseorientation=False, splitallsidesoptions='none', splitnumberedges=0, splitoptions='none', useinferredgeometry=1, useadjacentlayer=0, splitfreeedges=True)#
Splits shell element patches using patterns based on the patch shared edges.
- Parameters:
elem_collection (Collection) – The collection containing the element entities to split.
consider1ds (unsigned int) –
Check for 1D elements during the split operation. Valid values are:
0 - Splitting 1D elements disabled.
1 - Splitting 1D elements enabled. (default)
dividequadsoptions (hwString) –
The orientation of the diagonals of the selected elements after split. Valid values are:
ShortestDiagonals - Chooses the shortest diagonal in each element. (default)
AlignedDiagonals - Aligns all the diagonals in the same direction.
UnionjackDiagonals - Creates a union-jack pattern out of the diagonals.
LargestAngleDiagonals - Chooses the diagonal that splits the largest angle in the element.
midpointoptions (hwString) –
The element split pattern at the midpoint. Valid values are:
ToQuads - Splits quads and trias into quads only.
ToTrias - Splits quads and trias into trias only.
reverseorientation (bool) –
Check for switching to the other diagonal within each selected element.
False- The diagonals are not reversed. (default)True- The diagonals are reversed.splitallsidesoptions (hwString) –
The mode in which trias are split if SplitAllSides is the split mode. This option is effective only if
splitoptions="SplitAllSides"andsplitnumberedges=1.Valid values are:
Quads - Splits a tria into three quads. (default)
Mixed - Splits a tria into two trias and one quad.
splitnumberedges (unsigned int) – The number of splits in each edge of the selected elements. Default value is 1.
splitoptions (hwString) –
The split mode. Valid values are:
SplitAllSides - Splits each edge of the selected elements. (default)
DivideQuads - Divides selected quads along the diagonals.
Midpoint - Splits selected elements at their midpoint.
useinferredgeometry (unsigned int) –
Checks for using inferred geometry from the nodes when the underlying geometry is not specified.
0 - Do not use inferred geometry.
1 - Use inferred geometry.
useadjacentlayer (unsigned int) –
Checks for using a layer of adjacent elements as transition elements for split operations.
0 - Do not use adjacent layer. (default)
1 - Use an adjacent layer.
splitfreeedges (bool) – Reserved for future development.
Example#
Split the elements with IDs 10 and 11#import hm import hm.entities as ent model = hm.Model() model.splitelementbyelemselect( collection=hm.Collection(model, ent.Element, [10, 11]), consider1ds=1, splitallsidesoptions="Quads", splitnumberedges=5, splitoptions="SplitAllSides", useinferredgeometry=1, useadjacentlayer=0, )
