Model.ME_ModuleOccurrenceReparent#
- Model.ME_ModuleOccurrenceReparent(child_part_entity, parent_part_entity, options)#
Move a module part or part assembly underneath another part assembly in the model hierarchy. This is only allowed in cases where it does not break sub-assembly instancing.
- Parameters:
child_part_entity (Entity) – The object describing the part entity to move. The module must be an occurrence.
parent_part_entity (Entity) – The object describing the part entity to become the parent.
options (hwString) –
List of input options, passed as a comma separated string enclosed in quotes. Valid options are:
matrix_mode=<mode>
0 - Retain the relative position of the child module (default). This may cause the part to translate if there are matrices stored at different levels in the hierarchy.
1 - Retain the absolute position of the child module.
Example#
Reparente the part module with ID 100 under part assembly with ID 8 in the hierarchy, keep the absolute matrix#import hm import hm.entities as ent model = hm.Model() model.ME_ModuleOccurrenceReparent( child_part_entity=ent.Part(model, 100), parent_part_entity=ent.Part(model, 8), options="matrix_mode=1", )
