Model.morphmaptonodelistvecoffset#
- Model.morphmaptonodelistvecoffset(collection_nodes, collection_handles, node_list, use_symmetry, use_constraints, project, vector, mode, offset)#
Maps nodes to, or offset from, a specified line using the temporary shape created by
Model.morphmaptshp()andModel.morphmaptshpedge()as a guide. Selected handles can optionally follow behind the morphing operation.Nodes can be projected on to the line along a vector, normal to the line, or spaced evenly along the line (if the nodes belong to edge domains).
- Parameters:
collection_nodes (Collection) – The collection containing the input node entities.
collection_handles (Collection) – The collection containing the handle entities.
node_list (EntityList) – The list containing the target node entities.
use_symmetry (int) – 0 - Do not use symmetry (only option)
use_constraints (int) –
0 - Do not use constraints
1 - Use constraints
project (int) –
0 or 10 - Project along vector defined by vector_id
1 or 11- Project normal to line
2 - Fit to line
If
offsetis non-zero, the offset will be measured from the closest point on the line for values of 0 and 1.The offset will be measured along the projection vector or normal for values of 10 and 11. Offsets will not be applied for a value of 2.
vector (hwTriple) – The hwTriple object defining the vector components. User can also supply a Python list of three doubles.
mode (int) –
0 - If
Model.morphmaprecalc()has been used to calculate new influences1 - To recalculate new influences inside this function
offset (double) –
The distance to offset nodes from the target. Not used if
project=2.The offset will be measured from the closest point on the line for values of
projectof 0 and 1.The offset will be measured along the projection vector normal for values of
projectof 10 and 11.
Example#
Project nodes selected interactively normal to a line with ID 23 with an offset of 1.2 when not useModel.morphmaprecalc()#import hm import hm.entities as ent model = hm.Model() model.morphmaptonodelistvecoffset( collection_nodes=hm.CollectionByInteractiveSelection(model, ent.Node), collection_handles=hm.CollectionByInteractiveSelection(model, ent.Handle), node_list=[ent.Node(model, 23)], use_symmetry=0, use_constraints=1, project=1, vector=[1.0, 0.0, 0.0], mode=1, offset=1.2, )
