Model.acm_create_mpc#
- Model.acm_create_mpc(main_collection, secondary_collection, interface_collection, tolerance, behavior)#
Creates MPCs between selected main and secondary elements. It is extracted as a standalone functionality from the acoustic cavity mesher.
- Parameters:
main_collection (Collection) – The collection containing the element entities belonging to the main body.
secondary_collection (Collection) – The collection containing the element entities belonging to the secondary body.
interface_collection (Collection) – The collection containing the component entities that define patched holes.
tolerance (double) – The maximum search distance to use for finding independent nodes for each dependent node.
behavior (double) –
MPC creation behavior. Valid values are:
0 - By proximity only.
1 - By proximity and by intersection check with patched holes. Creates only those MPCs which intersect patched hole components.
2 - By proximity and by intersection check with patched holes. Creates only those MPCs which do not intersect patched hole components.
Example#
Produce MPCs between main elems in component 813 , secondary elements in comp 816 , and patch elements in component 812 , using a tolerance of 50.0 and creating MPCs using behavior 2#import hm import hm.entities as ent model = hm.Model() # Collection containing elements of component ID 813 mainElCol = hm.Collection( model, ent.Element, hm.Collection(model, ent.Component, [813]) ) # Collection containing elements of component ID 816 secElCol = hm.Collection( model, ent.Element, hm.Collection(model, ent.Component, [816]) ) # Collection containing component ID 812 patchElComp = hm.Collection( model, ent.Component, [812] ) model.acm_create_mpc( main_collection=mainElCol, secondary_collection=secElCol, interface_collection=patchElComp, tolerance=50.0, behavior=2, )
