Model.boolean_merge_solids#
- Model.boolean_merge_solids(entitycollectiona, entitycollectionb, opcode, options)#
Performs a Boolean operation on selected solid entities.
- Parameters:
entitycollectiona (Collection) – The collection containing the solid entities in set A.
entitycollectionb (Collection) – The collection containing the solid entities in set B.
opcode (int) –
The code of the Boolean operation to be performed. Valid options are:
2 - Set A minus set B.
8 - Set A or set B
14 - Set A and set B
options (int) –
Specifies how to process internal shared boundaries in resulted solid or solids. Valid values are:
0 - All boundaries shared between sets A and B are removed.
1 - Surfaces that were part of the boundary of solids in the set B are kept in the result.
2 - All shared boundaries are kept in the result.
3 - All shared boundaries are removed.
Note
Performs the same operation as
Model.boolean_solids()whenBooleanToleranceis not specified. TheModel.boolean_solids()should be used for combination operation of FE solids.Example#
Subtract solid with ID 20 from solid with ID 10#import hm import hm.entities as ent model = hm.Model() solid_set_A = hm.Collection(model, ent.Solid, [10]) solid_set_B = hm.Collection(model, ent.Solid, [20]) model.boolean_merge_solids(entitycollectiona=solid_set_A, entitycollectionb=solid_set_B, OpCode=2)
