Model.hm_istextcard#
- Model.hm_istextcard(entity)#
Returns 1, for control cards if it is a string array card, else it returns 0.
A card is a string array card if it has exactly three attributes:
Attributes 1 (template tag) and 2 (array size) are integers.
Attribute 3 is an array of strings.
- Parameters:
entity (Entity) – The object describing the entity whose control card you wish to evaluate.
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:isTextCard (unsigned int)
Example#
Check if card with ID 7 is a string array card#import hm import hm.entities as ent model = hm.Model() _, result = model.model.hm_istextcard(entity=ent.Card(model,7)) print("isTextCard", result.isTextCard)
