Model.voxel_lattice_hex_mesh_add_entities_with_buffer#
- Model.voxel_lattice_hex_mesh_add_entities_with_buffer(collection, num_buffer_layers)#
Adds entities to the voxel domain with a number of buffer layers. Voxel gridding is donealong the intersection profile of the entities and the buffer layer.This must be preceded by a call to
Model.voxel_lattice_hex_mesh_init()and must be followed by a call toModel.voxel_lattice_hex_mesh_create().- Parameters:
collection (Collection) – The collection containing the entities to be added. Valid entities are component, element, surface, solid and line entities.
num_buffer_layers (int) – The number of buffer layers.
Example#
Create voxels of size 10.0 to include components with IDs 100 - 110 with 3 buffer layers around comp 110 , and exclude components withIDs 200 - 203#import hm import hm.entities as ent model = hm.Model() # Creating a collection that contains the components to be included filter_in_components = hm.FilterByEnumeration(ent.Component, list(range(100, 110))) in_component_collection = hm.Collection(model, filter_in_components) # Creating a collection that contains the components to be excluded filter_out_components = hm.FilterByEnumeration(ent.Component, list(range(200, 204))) out_component_collection = hm.Collection(model, filter_out_components) # Creating a collection that contains the component to be added with buffer layers component_added_buffer_collection = hm.Collection(model, ent.Component, [110]) model.voxel_lattice_hex_mesh_init(voxel_size=10.0) model.voxel_lattice_hex_mesh_fill_voids(mode=0) model.voxel_lattice_hex_mesh_add_entities(collection=in_component_collection, mode=1) model.voxel_lattice_hex_mesh_add_entities_with_buffer( collection=component_added_buffer_collection, num_buffer_layers=3 ) model.voxel_lattice_hex_mesh_remove_entities( collection=out_component_collection, mode=1 ) model.voxel_lattice_hex_mesh_create() model.voxel_lattice_hex_mesh_end()
