Model.elementtestorthogonality#
Model.elementtestorthogonality(input_collection, orthogonality, output_collection, dimension, contour, title)#
Tests 3D elements for whether or not they pass the orthogonality element quality check, and puts those that fail on the specified outputmark.
Parameters:
  • input_collection (Collection) – The collection containing the element entities to test.
  • orthogonality (double) – The value to use as a threshold beyond which elements should be considered to have failed the test.
  • output_collection (Collection) – The collection containing the failed element entities.
  • dimension (int) –
    A code telling to measure the dimension of:
    4 - Measure 3D elements.
  • contour (int) –
    A code telling if should:
    0 - Display the results of the test normally.
    1 - Display the elements color coded by their ratings.
    2 - Build a histogram showing the distribution of ratings.
  • title (hwString) – The title to label the curve in the histogram.
Example#
Testing all displayed 3D elements for an orthogonality value less than 0.2#
import hm
import hm.entities as ent
model = hm.Model()
elems1 = model.CreateCollectionByDisplayed(ent.Element)
elems2 = hm.Collection(model, hm.FilterByEnumeration(ent.Element, ids=hm.hwUIntList([])))
model.elementtestorthogonality(input_collection,orthogonality,output_collection,dimension,contour,title)
    input_collection=elems1,
    orthogonality=0.2,
    output_collection=elems2,
    dimension=4,
    contour=0,
    title="3D Orthogonality"
