Model.hm_getelemcheckelems#
- Model.hm_getelemcheckelems(elementsCollection, dimension, check_type, check_mode, threshold=0, tolerance=0, time_failure=0.005)#
Returns the elements that match the specified element check criteria. Only the elements on
elementsCollectionand of the specified dimension are considered when determining which elements match the specified criteria.- Parameters:
elementsCollection (Collection) – The collection containing the element entities.
dimension (int) –
The dimension of the elements on
elementsto consider. Valid values are:1 - 1D elements
2 - 2D elements
3 - 3D elements
If no elements of the specified dimension are on
elements, an error is returned.check_type (hwString) –
The type of element check to return the bounds from. The allowable values depend on the
dimensionspecified:dimension=1: length, timestepdimension=2: addedmass, aspect, cellsquish, chordaldev, equiskew, jacobian, length, maxinterangle, maxlength, mininterangle, minlength, skew, taper, timestep, volumeareaskew, warpagedimension=3: addedmass, altitudeaspect, aspect, cellsquish, equiskew, jacobian, length, maxinterangle, maxlength, mininterangle, minlength, ortho_3d, size_ratio_3d, skew, taper, tetracollapse, timestep, volumeareaskew, volumetricskew, warpage
check_mode (hwString) –
The type of element check to perform. Valid values are:
above - Return the entities that are above the specified threshold value of the
check_typefrom the elements onelementsCollectionof the specified dimension.below - Return the entities that are below the specified threshold value of the
check_typefrom the elements onelementsCollectionof the specified dimension.exact - Return the entities that have the specified threshold value (within tolerance) of the
check_typefrom the elements onelementsCollectionof the specified dimension.max - Return the entity(ies) that have the maximum value of the
check_typefrom the elements onelementsCollectionof the specified dimension.min - Return the entity(ies) that have the minimum value of the
check_typefrom the elements onelementsCollectionof the specified dimension.threshold (double) – The threshold value to use when
check_modeis set to above, below or exact. This is ignored and not required whencheck_modeis set to max or min.tolerance (double) – The tolerance value to use when
check_modeis set exact. This is ignored and not required whencheck_modeis set to max, min, above or below.time_failure (double) – The value to use as a threshold beyond which the input elements should be considered to have failed the test. This is required only when
check_type="addedmass".
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:elements (EntityList) - Entity Type:
Element
Examples#
Get the 1D elements that have the minimum length from the elements in component with name “ comp1 “#import hm import hm.entities as ent model = hm.Model() element_collection = hm.Collection( model, ent.Element, hm.Collection(model, ent.Component, "name=comp1") ) _, result = model.hm_getelemcheckelems( elementsCollection=element_collection, dimension=1, check_type="length", check_mode="min", ) print("Element IDs:",[e.id for e in result.elements])
Get the 2D elements that have the maximum warpage from the displayed elements#import hm import hm.entities as ent model = hm.Model() element_collection = hm.CollectionByDisplayed(model, ent.Element) _, result = model.hm_getelemcheckelems( elementsCollection=element_collection, dimension=2, check_type="warpage", check_mode="max", ) print("Element IDs:", [e.id for e in result.elements])
Get the 2D elements that have a warpage above 5.0 from the displayed elements#import hm import hm.entities as ent model = hm.Model() element_collection = hm.CollectionByDisplayed(model, ent.Element) _, result = model.hm_getelemcheckelems( elementsCollection=element_collection, dimension=2, check_type="warpage", check_mode="above", threshold=5.0, ) print("Element IDs:", [e.id for e in result.elements])
Get the 3D elements that have a tetracollapse below 0.1 from all elements#import hm import hm.entities as ent model = hm.Model() element_collection = hm.Collection(model, ent.Element) _, result = model.hm_getelemcheckelems( elementsCollection=element_collection, dimension=3, check_type="tetracollapse", check_mode="below", threshold=0.1, ) print("Element IDs:", [e.id for e in result.elements])
Get the 3D elements that have a jacobian of exactly 1.0 from all elements , with a tolerance of 0.01#import hm import hm.entities as ent model = hm.Model() element_collection = hm.Collection(model, ent.Element) _, result = model.hm_getelemcheckelems( elementsCollection=element_collection, dimension=3, check_type="jacobian", check_mode="exact", threshold=1.0, tolerance=0.01, ) print("Element IDs:", [e.id for e in result.elements])
