Model.hm_holedetectiongetwasherelementslist#
- Model.hm_holedetectiongetwasherelementslist(index)#
Returns the washer elements layer-wise. This must be preceded by a call to
Model.hm_holedetectionfindholes().- Parameters:
index (int) – The index of the node/line to get the associated hole index.
- Returns:
hwReturnStatus- Status objectHmQueryResultList- Result list object containingHmQueryResultobjects with the following output data:entityList (EntityList) - Entity Type:
Element
Example#
Detect holes on all elements in the model and write out to a text file the washer elements layer by layer for each detected hole that has a washer#import hm import hm.entities as ent model = hm.Model() with open("C:/temp/washer.txt", "w") as washersfile: model.hm_holedetectioninit() elem_collection = hm.Collection(model, ent.Element) model.hm_holedetectionsetentities(collection=elem_collection) model.hm_holedetectionfindholes(find=1) # For holes we need to set find=1 _, result = model.hm_holedetectiongetnumberofholes() num_holes = result.numberOfHoles if num_holes > 0: washersfile.write(f"Number of Shell Holes = {num_holes}\n") for n in range(num_holes): _, result = model.hm_holedetectiongetwasherelementslist(index=n) holedetailslist = result.entityList washersfile.write(f"hole index = {n, holedetailslist}\n") model.hm_holedetectionend() washersfile.close()
