Model.ME_ModuleOccurrenceClone#
- Model.ME_ModuleOccurrenceClone(part_entity, copy_contents=1, matrix=hwMatrix44(1.0), name='')#
Create a module as a copy of another. Module contents are copied unless specified otherwise.
- Parameters:
part_entity (Entity) – The object describing the part entity to clone.
copy_contents (int) –
0 - Do not copy contents.
1 - Default. Copy contents.
matrix (hwMatrix44) – A list of 16 doubles that describe the 4x4 relative transformation matrix.
name (hwString) – The name of the new module. If not specified, the new module will get a default name <original name>.i.<number of instances of the same prototype>>.
Examples#
Create a copy of module with ID 3 with a default name and without copy the contents#import hm import hm.entities as ent model = hm.Model() model.ME_ModuleOccurrenceClone(part_entity=ent.Part(model, 3), copy_contents=0)
Create a copy of module with ID 3 named “MyClone” copy all contents, and specify a unit transformation matrix#import hm import hm.entities as ent model = hm.Model() model.ME_ModuleOccurrenceClone( part_entity=ent.Part(model, 3), copy_contents=1, matrix=hm.hwMatrix44(1, 0, 0, 0, 0, 1, 0, 0, 0, 0, 1, 0, 0, 0, 0, 1), name="MyClone", )
