Model.xelem_bysetid#
- Model.xelem_bysetid(node_set_id)#
Creates a new element (/XELEM) of config 27 and type 1 using a node set. This is currently only supported for Radioss.
- Parameters:
node_set_id (int) – The ID of the node set to create the element from. The set must be an ordered node set of type /GRNOD/NODENS, and must contain at least two nodes.
Example#
Create an * * /XELEM * * element with ordered node set of ID 5#import hm import hm.entities as ent model = hm.Model() model.xelem_bysetid(node_set_id=5)
