Model.min_size_node_movement#
- Model.min_size_node_movement(collection)#
Moves nodes along feature edges in a shell mesh to solve minimum element size failures. The mesh topology is not modified. The minimum element size is given by “Min Size” ( fail ) in the criteria file settings. The node movement is restricted to be along existing surfaces. The function expects that the criteria and parameter files are set. It honors the following fields from the parameter file to specify the maximum allowable node movement distance:
Move across shared edges
Move across free edges
Move across non-manifold edges
Feature edges are constructed as:
A set of 1D elements along FE edges
If no 1D element is present in the model, using the feature angle given in the parameter file
Node - geometry association
Node - geometry association is maintained after feature node are moved, however, free edge nodes may move tangential away from the surface and lose association.
Feature node movement is attempted in decreasing order of priority for:
Internal low curvature shared edges
Internal high curvature edges
Free edges
Non-manifold edges
Node movement is also part of the
rebuild_mesh()function.- Parameters:
collection (Collection) – The collection containing the element entities to correct.
Example#
Move feature nodes of selected shell elements with 5 mm criteria and parameter file settings#import hm import hm.entities as ent model = hm.Model() model.setqualitycriteria( string_array=[ " 0 penalty value 0.00 0.00 0.80 1.00 10.00", " 1 min length 1 1.0 3.000 2.749 1.502 1.000 0.749 1", " 2 max length 1 1.0 3.000 3.600 4.500 6.000 9.000 0", " 3 aspect ratio 1 1.0 1.000 2.000 4.400 5.000 10.000 0", " 4 warpage 1 1.0 0.000 5.000 13.000 15.000 30.000 0", " 5 max angle quad 1 1.0 90.000 110.000 134.000 140.000 160.000 0", " 6 min angle quad 1 1.0 90.000 70.000 46.000 40.000 20.000 0", " 7 max angle tria 1 1.0 60.000 80.000 112.000 120.000 150.000 0", " 8 min angle tria 1 1.0 60.000 50.000 34.000 30.000 15.000 0", " 9 skew 1 1.0 0.000 10.000 34.000 40.000 70.000 0", "10 jacobian 1 1.0 1.000 0.900 0.700 0.600 0.300 0", "11 chordal dev 0 1.0 0.000 0.300 0.800 1.000 2.000 0", "12 taper 1 1.0 0.000 0.200 0.500 0.600 0.900 0", "13 % of trias 1 1.0 0.000 6.000 10.000 15.000 20.000 0", ], mode=0, ) model.elementchecksettings( solver=-1, jacobian_2d=0, jacobian_3d=0, min_len_2d=2, min_len_3d=1, aspect_2d=0, aspect_3d=0, skew_2d=0, skew_3d=0, angle=0, warpage=0, taper=0, chord_dev=0, tetra_collapse=0, cell_squish_2d=0, equi_skew_2d=0, cell_squish_3d=0, equi_skew_3d=0, time_step=0, reserved_1=0, reserved_2=0, reserved_3=0, reserved_4=0, ) batch_options = [ "geometry_cleanup_flag 1", "meshing_flag 5", "element_size 5.0", "element_type 2", "mesh_align 3", "element_order 1", "surf_component 1", "feature_angle 30.0", "holes_table_begin", "appl_surf(1)" "appl_solid(0)" "appl_cordsfiles(0)" "appl_flanged_suppr(1)" "flanged_suppr_height(1.4)" "narrow_slots_type(0)" "abs_fixed_nodes_count_max(-8)" "rad(0.0,2.2) do action(1) washer(0) ", "rad(2.2,3.01) do action(0) elems(4) washer(0) ", "rad(3.01,4.7) do action(0) elems(6) washer(1) layers(3.5) ", "rad(4.7,9.0) do action(0) elems(8) washer(1) layers(0.75*radius) ", "rad(9.0,11.0) do action(0) elems(8) washer(1) layers(7.0) ", "rad(11.0,20) do action(0) elems(8) washer(1) layers(auto) ", "rad(0.0,2.2) solid(1) do action(1) ", "rad(2.2,3.01) solid(1) do action(0) elems(4) ", "rad(3.01,20) solid(1) do action(0) elems(6) ", "holes_table_end", "edge_fillet_recognition 1", "max_fillet_radius 5.0", "surface_fillet_table_begin", "surface_fillet_recognition(1)" "minimize_transitions(1)" "rad(0,2.2) wid(3.0,6.2) do split(suppress_on)" "rad(2.2,15) wid(3.4,6.2) do elems(1)" "rad(0,25.0) wid(6.2,9.2) do elems(2)" "rad(0,35.0) wid(9.2,12.5) do elems(3)" "rad(0,40.0) wid(12.5,25.0) do chordal_deviation(0.2)" "surface_fillet_table_end", "del_dupl_surfs_flag 2", "del_dupl_surfs_tol -1", "edges_stitch_flags 0", "max_edges_stitch_tol -1.0", "fix_overlapsurfs_flag 1", "overlapsurfs_maxtangangle -1.0", "narrow_surfs_merge_width -1.0", "narrow_surfs_treat_flags 3", "beads_suppression 1", "beads_recognition 1", "minimal_beads_height 1.4", "beads_treat_flags 0", "flange_recognition 1", "flange_elements_across 3", "flange_max_width 30.0", "flange_min_width 8.0", "flanges_treat_flags 1", "flange_max_remove_width -1.0", "appl_tria_reduction 1", "tria_redu_max_elemsize auto", "tria_redu_min_elemsize auto", "trias_around_holes 0", "common_mesh_flow 0", "extract_thinsolids 1", "midsurf_method 3", "thinsolid_ratio 0.3", "max_thickness 10.0", "extract_feature_angle 25.0", "pre_midsurf_cleanup 1", "direct_midmesh 0", "ignore_flat_edges 1", "flatten_connections 0", "defeat_open_width_on 1", "defeat_open_width 1.0", "supp_proxim_edges_on 1", "supp_proxim_edges 0.5", "combine_nonmanifold_on 1", "combine_nonmanifold 0.5", "midmesh_extact_elem_size 10.0", "remove_logo 1", "logo_max_size 30.0", "logo_max_height 1.4", "logo_min_concavity 1.0", "threads_removal 0", "threads_toremove_max_depth 5.0", "threads_replacediametertype -2", "folded_elems_angle 150.0", "smooth_elems_target 0.2", "fillets_mesh_flow 0", "failed_elems_cleanup_flgs 8", "move_nodes_across_feature_edges 1", "featureedge_nodes_moveacross_max 0.1", "move_nodes_across_free_edges 1", "freeedge_nodes_moveacross_max 0.05", "move_normal_flag 1", "move_normal_dist 0.8", "divide_warped_quads 1", "ignore_comps_boundary 0", "gen_topology_prepare_flags 7", "cleanup_comp_flag 0 ", "comp_select ", "use_wildcards_for_compsnames 0", "cleanup_tolerances auto", "suppress_features_rate 0", "feat_charsize_method 0", "custom_feat_suppr_maxangle 25.0", "uncond_constr_lines_suppress 0", "aggressive_fillet_lines_suppress 0", ] model.createbatchparamsfromstrings(strings=batch_options) elem_collection = hm.Collection(model, ent.Element) model.min_size_node_movement(collection=elem_collection)
