Model.attributeupdate_entityidarray2d#
Model.attributeupdate_entityidarray2d(entity, identifier, solver, status, behavior, target_entity)#
Updates an attribute that is a 2D array (list) of entity lists (EntityList2()).
Parameters:
  • entity (Entity) – The object describing the entity that owns the attribute.
  • identifier (int) – The identifier of the attribute.
  • solver (int) – The solver number of the attribute.
  • status (int) – The status of the attribute.
  • behavior (int) – The behavior of the attribute.
  • target_entity (EntityList2) – The list of entity lists to which the attribute refers.
Example#
Update the load collectors in * FLLWER_LSID_ARRAY2D * dataname (identifier=10086 ) in Load collector with ID 24 in Optistruct profile#
import hm
import hm.entities as ent
model = hm.Model()
# Finding the FLLWER_LSID_ARRAY2D identifier using the hm_attributeidentifier function
_, r = model.hm_attributeidentifier(
    entity_type=ent.Loadcol, entity_id=24, attribute_name_or_id="FLLWER_LSID_ARRAY2D"
newloadcolsList = [
    [ent.Loadcol(model, 22), ent.Loadcol(model, 14)],
    [ent.Loadcol(model, 18), ent.Loadcol(model, 41)],
# Setting the dataname
model.attributeupdate_entityidarray2d(
    entity=ent.Loadcol(model, 1),
    identifier=r.id,
    solver=1,
    status=2,
    behavior=0,
    target_entity=newloadcolsList,
