Model.CE_ConnectorAreaCreateFromList#
- Model.CE_ConnectorAreaCreateFromList(entitylist, width, offset, linkcollection, ent_state, ce_rules, ce_le_rule, tol_flag, tolerance, group, param1, param2)#
Create area connector(s) at the specific location(s) by list with certain rules.
- Parameters:
entitylist (EntityList) – The list for input line or node entities that specify location of area connector(s).
width (double) – The width of area connector(s).
offset (double) – Create area connnector(s) offset this value from selected location.
linkcollection (Collection) – The collection containing the entities to add to the area connector as links. Valid entities are surfaces and components
ent_state (unsigned int) –
Specifies whether geometry or element gets precedence during realization of connector. Currently, only element is supported.
0 - Geometry.
1 - Element.
ce_rules (unsigned int) –
Rule to specify if and how a link entity is to be added to a connector.
0 - None.
1 - Now.
2 - A fe realize.
ce_le_rule (unsigned int) –
Rule that specifies how an entity is to be remembered by the connector.
0 - None.
1 - Use ID.
2 - Use name.
tol_flag (unsigned int) –
Specifies if tolerance value is applicable.
0 - Use default.
1 - Use specified value.
tolerance (double) – Specified to add entities only within the given tolerance from the connector.
group (int) –
Specified if to group after creation.
0 - Do not group.
1 - Group.
param1 (int) – Reserved for future development.
param2 (double) – Reserved for future development.
Example#
Create 2 area connector at lines with IDs 1, 2, 3, 6, 7, 8 and add nearest 2 of the four components specified within a tolerance of 1.0. Remember the components by their IDs. do not group connectors after creation#import hm import hm.entities as ent model = hm.Model() model.CE_ConnectorAreaCreateFromList( entitylist=[ ent.Line(model, 1), ent.Line(model, 2), ent.Line(model, 3), ent.Line(model, 6), ent.Line(model, 7), ent.Line(model, 8), ], width=10.0, offset=0.0, linkcollection=hm.Collection(model, ent.Component, [21, 23, 24, 27]), ent_state=1, ce_le_rule=1, ce_rules=1, tol_flag=1, tolerance=1.0, group=0, param1=0, param2=0.0, )
Note
Each created area connector is displayed as a plane with cylinders located at the corners and only the closest two components are added to it. The total number of layers defined at each area connector is 2.
