Model.hm_getclosestpointsbetweentwolines#
Model.hm_getclosestpointsbetweentwolines(line1, line2)#
Find the shortest distance between two lines and return line points corresponding to this distance.
Parameters:
  • line1 (Entity) – The object describing the first line entity.
  • line2 (Entity) – The object describing the second line entity.
Returns:
  • hwReturnStatus - Status object
  • HmQueryResult - Result object containing the output values:
    • closestPoint1 (numpy.ndarray) - The closest point on the first line
    • closestPoint2 (numpy.ndarray) - The closest point on the second line
Example#
Find closest points between lines with IDs 1 and 2#
import hm
import hm.entities as ent
model = hm.Model()
_, result = model.hm_getclosestpointsbetweentwolines(
    line1=ent.Line(model, 1), line2=ent.Line(model, 2)
print("Closest point to line 1:", result.closestPoint1)
print("Closest point to line 2:", result.closestPoint2)
