Model.beamsectionsetdataroot#
Model.beamsectionsetdataroot(beam_sect_id, collector_id, solver, beam_config, line_color, fill_color, flags, torsion_factor, warping_factor, orient_vector1, orient_vector2, orient_origin1, orient_origin2)#
Updating a beam section requires two functions, of which this is the first. This function updates the root data for a beam section and will also clear all other beam section data.
Thus, this function should be followed by Model.beamsectionsetdatastandard(), Model.beamsectionsetdatashell(), Model.beamsectionsetdatasolid(), or Model.beamsectionsetdatageneric() depending on the beam_config selected. Beam section data cannot be updated piecemeal with this function; all data must be known for the beam and sent in as arguments.
Parameters:
  • beam_sect_id (unsigned int) – The ID of the beam section to update.
  • collector_id (unsigned int) – The ID of the beam section collector to update.
  • solver (unsigned int) –
    Integer indicating the solver the section is for. Valid values are:
    0 - HyperBeam
    1 - OptiStruct/Nastran
    2 - Abaqus
    8 - ANSYS
    9 - LS-DYNA
    21 - Permas
  • beam_config (int) –
    Basic configuration of the beam section. Valid values are:
    0 - Solid section
    1 - Generic section
    2 - Standard section
    3 - Shell section
  • line_color (unsigned char) – Currently unused. Must be set to 7.
  • fill_color (unsigned char) – Currently unused. Must be set to 1.
  • flags (unsigned char) – Currently unused. Must be set to 0.
  • torsion_factor (double) – Currently unused. Must be set to 1.
  • warping_factor (double) – Currently unused. Must be set to 1.
  • orient_vector1 (double) – Currently unused. Must be set to 0.
  • orient_vector2 (double) – Currently unused. Must be set to 0.
  • orient_origin1 (double) – Currently unused. Must be set to 0.
  • orient_origin2 (double) – Currently unused. Must be set to 0.
Examples#
Update the root data for a standard section specifying HyperMesh as the solver type#
import hm
import hm.entities as ent
model = hm.Model()
model.beamsectionsetdataroot(
  beam_sect_id=1,
  collector_id=1,
  solver=0,
  beam_config=2,
  line_color=7,
  fill_color=1,
  flags=0,
  torsion_factor=1,
  warping_factor=1,
  orient_vector1=0,
  orient_vector2=0,
  orient_origin1=0,
  orient_origin2=0
Note that this function should be used in tandem with one of four beam section update functions such as Model.beamsectionsetdatastandard() as follows#
import hm
model = hm.Model()
  beam_sect_id=1,
  collector_id=1,
  solver=0,
  beam_config=2,
  line_color=7,
  fill_color=1,
  flags=0,
  torsion_factor=1,
  warping_factor=1,
  orient_vector1=0,
  orient_vector2=0,
  orient_origin1=0,
  orient_origin2=0
model.beamsectionsetdatastandard(
  parameter_array=[6.0, 6.0, 6.0, 0.5, 0.5, 0.5, 4.0, 4.0, 4.0, 1.0, 1.0, 1.0],
  beam_sect_id=1,
  beam_sect_type=4,
  orientation_angle=0,
  beam_sect_subtype="HMHat"
