Model.tetmesh_set_input#
- Model.tetmesh_set_input(collection1, mode1, collection2, mode2)#
Supplies additional input to
tetmesh().For the special case that both inputs are inactive, this function clears selections from all previous calls to
tetmesh()andModel.tetmesh_set_input(). This is normally not necessary since such cleanup is normally done at the end of each call totetmesh().- Parameters:
collection1 (Collection) – The collection containing the first entities. Valid entities are nodes, elements, components, surfaces and solids. If
collection1is empty then it is considered inactive input.mode1 (int) –
-1 - Ignored (inactive input)
0 - Float without boundary layer
1 - Fixed without boundary layer
2 - Float with boundary layer
3 - Fixed with boundary layer
4 - Size control boxes
5 - Anchor nodes
6 - 3D re-mesh
7 - 3D re-mesh with free boundary swappable-float
8 - 3D re-mesh with free boundary remeshable-float
9 - Remeshable-float without BL
10 - Remeshable-float with BL
11 - Elem input for fluid volume selection. Either touched (or normal pointed into) are fluid volumes
collection2 (Collection) – The collection containing the second entities. Valid entities are nodes, elements, components, surfaces and solids. If
collection2is empty then it is considered inactive input.mode2 (int) –
5 - Anchor nodes
6 - 3D re-mesh
Example#
import hm import hm.entities as ent model = hm.Model() # Create Tetramesh elements_col = hm.Collection(model, ent.Element, populate=False) str_array = ["tet: 35 1.3 -1 0.014 0.8 0 0 1"] comps_list_input_tetmesh = [ comp for comp in hm.Collection(model, ent.Component) if comp.name in ("^elem_size_ctrl_0.1", "^elem_size_ctrl_0.5") ] comps_col_input_tetmesh = hm.Collection(comps_list_input_tetmesh) model.tetmesh_set_input(collection1=comps_col_input_tetmesh,mode1=4,collection2=hm.Collection(model,ent.Element,populate=False),mode2=-1) col1_tet=hm.Collection(model,ent.Component,"name=float_shells") col2_tet=hm.Collection(model,ent.Component,"name=fixed_shells") model.tetmesh( collection1=col2_tet, mode1=0, collection2=col1_tet, mode2=1, string_array=str_array, )
