Model.hm_holedetectiongetholedetailsdata#
Model.hm_holedetectiongetholedetailsdata(index, query_key)#
Returns details about a specific query for a hole/tube.
The hole can be general, circular, square and rectangular.
The tude can be general, circular, square and rectangular.
Parameters:
  • index (int) – The index of the hole/tube to get details for, starting from 0.
  • query_key (hwString) –
    The keyword to be used for a specific shape type. Valid values are:
    axis
    The x/y/z coordinates of the axis. Valid for all holes.
    axis_bottom
    The x/y/z coordinates of the bottom axis. Valid for all tubes.
    axis_top
    The x/y/z coordinates of the top axis. Valid for all tubes.
    capped_flag
    Returns true if there is a capped hole. Valid for all tubes.
    center
    The x/y/z coordinates of the center. Valid for all holes.
    center_bottom
    The x/y/z coordinates of the bottom center. Valid for all tubes.
    center_top
    The x/y/z coordinates of the top center. Valid for all tubes.
    depth
    The tube depth. Valid for all tubes.
    entities_list
    The list of ordered nodes or lines. Valid for all holes.
    has_washer
    Returns true if there is a washer. Valid for all 2D mesh holes.
    length
    The side length. Valid for square/rectangular holes.
    length_bottom
    The bottom side length. Valid for square/rectangular tubes.
    length_top
    The top side length. Valid for square/rectangular tubes.
    radius
    The circular radius. Valid for circular holes.
    radius_bottom
    The bottom circular radius. Valid for circular tubes.
    rim_entities_bottom
    The bottom list of ordered nodes or lines. Valid for all tubes.
    rim_entities_top The top list of ordered nodes or lines. Valid for all tubes.
    radius_top The top circular radius. Valid for circular tubes only.
    shape_type
    The shape type. Valid for all holes/tubes.
    tube_barrel_info
    The number of barrels, barrel types, and entity IDs in the format {number_of_barrels {barrel_type {surface/element/face IDs}}}. Valid for all tubes.
    tube_entities_list
    The list of tube surfaces, shells, or solids and face indices. Valid for all tubes.
    width
    The side width. Valid for rectangular holes.
    width_bottom
    The bottom side width. Valid for rectangular tubes.
    width_top
    The top side width. Valid for rectangular tubes.
Returns:
Example#
Detect holes of any shape in all surfaces in the model and write the hole details shape_type, center, radius, and entities_list to a text file.#
import hm
import hm.entities as ent
model = hm.Model()
with open("C:/temp/holes.txt", "w") as holesfile:
    surf_collection = hm.Collection(model, ent.Surface)
    model.hm_holedetectioninit()
    model.hm_holedetectionsetentities(collection=surf_collection)
    model.hm_holedetectionsetholeparams(hole_shape=31)
    model.hm_holedetectionfindholes(find=1)  # For holes we need to set find=1
    _, result = model.hm_holedetectiongetnumberofholes()
    num_holes = result.numberOfHoles
    if num_holes > 0:
        holesfile.write(f"Number of holes = {num_holes}\n\n")
        for n in range(num_holes):
            holesfile.write(f"Queried data details of hole {n+1}\n")
            _, result = model.hm_holedetectiongetholedetailsdata(
                index=n, query_key="shape_type"
            holesfile.write(f"shape-type = {result.queryValue}\n")
                index=n, query_key="center"
            holesfile.write(f"center = {result.queryValue}\n")
                index=n, query_key="radius"
            holesfile.write(f"radius = {result.queryValue}\n")
                index=n, query_key="entities_list"
            holesfile.write(f"entities_list = {result.queryValue}\n\n")
    else:
        holesfile.write("Holes not detected.\n")
    model.hm_holedetectionend()
    holesfile.close()
