Model.linemesh_saveparams#
- Model.linemesh_saveparams(line, break_angle=0.0, segment_id=-1, elem_density=0, bias_intensity=-1.0, bias_style=-1, use_chordal_values=0, min_size=0.0, max_size=0.0, max_deviation=0.0, max_angle=0.0)#
Assigns meshing parameters to the input line for 1D meshing. If break_angle is defined, the input line might be broken into several segments by this angle and the function needs to be used separately to set parameters for each segment of this line, since different parameters might be assigned to different segments. In that case,
segment_idspecifies to which segment of the broken line the function parameters are applied.The 1D mesh parameters on the input line, or on one of its segments, can be set by either of the following two ways:
specify
elem_density,bias_intensityandbias_style
OR
specify
use_chordal_values,min_size,max_size,max_deviationandmax_angle
The function must be paired with a call to Model.linemesh_preparedata1, which initializes the mesh server for a set of lines, with some initial parameters, including the element configuration.
- Parameters:
line (Entity) – The line entity for which the mesh parameters are set.
break_angle (double) – If a break angle is given, the input line might be broken into several segments depending on the value of the break angle. Then we use
segment_id, to specify to which segment the parameters are applied.segment_id (int) – When the input line is broken into several segments with a break angle, this argument is used to specify to which segment the parameters are applied. Segment IDs start with 0, which refers to the first segment of the broken line.
elem_density (int) – The element density to use for the specified segment.
bias_intensity (double) – The biasing value of the element length to use along the given segment.
bias_style (int) –
The style of biasing to use. Valid values are:
0 - linear
1 - exponential
2 - bell curve
use_chordal_values (unsigned int) –
Argument to specify if the parameters are set by using chordal values or not. Valid values are:
0 - not using chordal values. In this case,
elem_densityandbias_intensityshould be provided as input arguments.1 - using chordal values. In this case,
min_size,max_size,max_deviationandmax_angleshould be provided as input arguments.min_size (double) – The required lower bound for the element size to use in meshing.
max_size (double) – The required upper bound for the element size to use in meshing.
max_deviation (double) – The required maximum deviation for the element size in meshing.
max_angle (double) – The required maximum angle between the elements in meshing.
Example#
To mesh the lines ID 12 and 31, using break_angle 30.0. Assume that this angle breaks line ID 31 into two segments (segment 0 and segment 1). In this case, we need to use Model.linemesh_saveparams for each of these segments separately.#import hm import hm.entities as ent model = hm.Model() lines = hm.Collection(model, ent.Line, [12, 31]) model.linemesh_preparedata1(collection=lines, break_angle=30.0, config=2) model.linemesh_saveparams( line=ent.Line(model, 12), break_angle=30.0, segment_id=0, use_chordal_values=1, min_size=0.5, max_size=5.0, max_deviation=0.1, max_angle=15.0, ) model.linemesh_saveparams( line=ent.Line(model, 31), break_angle=30.0, segment_id=0, elem_density=9, bias_intensity=7, bias_style=1, ) model.linemesh_saveparams( line=ent.Line(model, 31), break_angle=30.0, segment_id=1, elem_density=6, bias_intensity=8, bias_style=2, ) model.linemesh_savedata1(create_flag=1, config=2, property_id=0, organize=0)
