Model.surfacemarkremovelinefillets#
Model.surfacemarkremovelinefillets(collection, min_radius, max_radius, min_angle, double_array)#
Defeatures specific surface edge fillets.
Parameters:
  • collection (Collection) – The collection containing the surface entities to defeature the edge fillets.
  • min_radius (double) – The minimum value of the fillet radius.
  • max_radius (double) – The maximum value of the fillet radius.
  • min_angle (double) – Minimum value of the fillet angle (in degrees).
  • double_array (hwDoubleList) – The list of doubles that contains the coordinates of the fillets to defeature.
Example#
Delete 3 edge fillets with coordinates [ ( 112.800768 , -97.9869801 , 90.4349669 ) ( 113.103246 , 71.2980238 , 87.1212897 ) and ( -118.799245 , -97.7195516 , 110.804638 ) ] with a radius between 3.0 and 5.0 , and an angle greater than 15.0 degrees#
import hm
import hm.entities as ent
model = hm.Model()
model.surfacemarkremovelinefillets(
    collection=hm.Collection(model, ent.Surface),
    min_radius=3.0,
    max_radius=5.0,
    min_angle=15.0,
    float_array=[
        112.800768,
        -97.9869801,
        90.4349669,
        113.103246,
        71.2980238,
        87.1212897,
        -118.799245,
        -97.7195516,
        110.804638,
