Model.elementtestequiaskew#
Model.elementtestequiaskew(collection, equiangle_skew, output_collection, dimension, contour, title)#
Tests 2D and 3D elements using the equiangle skew element quality check.
Parameters:
  • collection (Collection) – The collection containing the element entities to test.
  • equiangle_skew (double) – The value to use as a threshold beyond which elements should be considered to have failed the test.
  • output_collection (Collection) – The collection containing the failed element entities.
  • dimension (int) –
    A code telling to measure the dimension of:
    2 - Measure 2D elements.
    4 - Measure 3D elements.
  • contour (int) –
    Flag that determines how the results are presented. Valid values are:
    0 - Display the results of the test normally.
    1 - Display the elements color coded by their ratings.
    2 - Build a histogram showing the distribution of ratings.
  • title (hwString) – The title to label the curve in the histogram. Only required, if contour is 2.
Example#
Test all displayed elements for a cell squish of 0.7#
import hm
import hm.entities as ent
model = hm.Model()
elems1 = model.CreateCollectionByDisplayed(ent.Element)
elems2 = hm.Collection(model, hm.FilterByEnumeration(ent.Element, ids=hm.hwUIntList([])))
model.elementtestequiaskew(
    collection=elems1,
    equiangle_skew=0.7,
    output_collection=elems2,
    dimension=0,
    contour=0,
    title=""
