Model.surfacemarkclipwithline#
- Model.surfacemarkclipwithline(collection, line, tolerance)#
Splits a group of surfaces with a line by projecting that line perpendicularly onto the surfaces.
- Parameters:
collection (Collection) – The collection containing the surface entities to be splitted.
line (Entity) – The entity line used to split the surfaces.
tolerance (double) – The tolerance value to be used when projecting the line onto the surfaces.
Example#
Split the surfaces with IDs 171 and 172 use the line with ID 26#import hm import hm.entities as ent model = hm.Model() surf_col = hm.Collection(model, ent.Surface, [171, 172]) line = ent.Line(model, 26) model.surfacemarkclipwithline(collection=surf_col, line=line, tolerance=0.1)
