Model.CE_ConnectorAreaMeshWithDetails#
Model.CE_ConnectorAreaMeshWithDetails(collection, element_size, element_type, element_type2, link_opposite_edges, size_control, skew_control, edge_mesh_algorithm, min_size, max_size, chordal_deviation, max_angle, area_width, area_offset)#
Meshes area connectors and updates the width and offset stored on the connector.
Parameters:
  • collection (Collection) – The collection containing the area connectors.
  • element_size (double) – The element size.
  • element_type (int) –
    The element type for mapped meshing algorithms:
    0 - Trias
    1 - Quads
    2 - Mixed
    3 - R-trias
  • element_type2 (int) –
    The element type for free meshing algorithms:
    0 - Trias
    1 - Quads
    2 - Mixed
    3 - R-trias
  • link_opposite_edges (int) –
    0 - Do not link
    1 - Link
  • size_control (int) –
    0 - Off
    1 - On
  • skew_control (int) –
    0 - Off
    1 - On
  • edge_mesh_algorithm (int) –
    0 - Standard
    1 - Chordal deviation
  • min_size (double) – The minimum element size when edge_mesh_algorithm = 1.
  • max_size (double) – The maximum element size when edge_mesh_algorithm = 1.
  • chordal_deviation (double) – The chordal deviation value when edge_mesh_algorithm = 1.
  • max_angle (double) – The maximum angle between edges when edge_mesh_algorithm = 1.
  • area_width (double) – The new width value.
  • area_offset (double) – The new offset value.
Example#
Update area connector with ID 10 with width 2.0 and mesh it with a default edge size of 1.0#
import hm
import hm.entities as ent
model = hm.Model()
connector_collection = hm.Collection(model, ent.Connector, [10])
model.CE_ConnectorAreaMeshWithDetails(
    collection=connector_collection,
    element_size=1.0,
    elem_type=1,
    elem_type2=1,
    link_opposite_edges=1,
    size_control=0,
    skew_control=0,
    edge_mesh_algorithm=0,
    min_size=0,
    max_size=0,
    chordal_deviation=0,
    max_angle=0,
    area_width=2.0,
    area_offset=0.0
