Model.mechadjustjoint#
- Model.mechadjustjoint(name, direction, value, tolerance, lock, angle_step, hold_angles=1)#
Actuates a joint to reach a new value.
The mechanism must have the enabled flag set to true for this to be possible.
- Parameters:
name (hwString) – The name of the joint to adjust.
direction (unsigned int) –
The direction along which the new value will be applied:
0 - Translation along x-axis
1 - Translation along y-axis
2 - Translation along z-axis
3 - Rotation about x-axis
4 - Rotation about y-axis
5 - Rotation about z-axis
value (double) – The desired value of the joint.
tolerance (double) – The tolerance allowed when adjusting.
lock (unsigned int) – If set to 1, all joints in the mechanism which are not part of the cycle of the given joint are locked.
angle_step (double) – The size of the iterative steps used to solve for the new value of the joint. Only used for rotation.
hold_angles (unsigned int) – If set to 1, this locks the rotation about axes other than the given direction. If 0, rotation occurs in a way such that the given axis doesn’t move. In this case the Euler angles about other axes can change. This is only for ball joints.
Example#
Move a joint named “TORSO_to_RIGHT_UPPER_LEG” tox=20.0,y=0.0,z=0.0with tolerance 0.001 , lock other joints and angle step = 0.0 :#import hm import hm.entities as ent model = hm.Model() model.mechadjustjoint( name="TORSO_to_RIGHT_UPPER_LEG", direction=0, value=20.0, tolerance=0.001, lock=1, angle_step=0.0, )
