Model.hm_comparegetarea#
- Model.hm_comparegetarea(match_type, match_location, transformation_index=0)#
Calculates the area values for all source and target entities. This must be preceded by a call to a relevant hm_compareentities function.
- Parameters:
match_type (int) –
The type of match to query for the area. Valid values are:
0 - Unmatched
1 - Topological
2 - Intersected
3 - Overlapped
4 - Matched
match_location (int) –
The location of the entities to query for the area. Valid values are:
1 - Source entities
2 - Target entities
transformation_index (int) – The index of the transformation to query, starting with 0. The number of transformations can be found using
Model.hm_comparegettransformationcount().
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:areaPercent (double)
Example#
Generate a contour of the distance results for a same side comparison of elements with IDs 1-20 and 101-120#import hm import hm.entities as ent model = hm.Model() elems1 = hm.Collection(model, ent.Element, list(range(1, 21))) elems2 = hm.Collection(model, ent.Element, list(range(101, 121))) model.hm_compareinit() model.hm_compareentitiessameside( source_entities=elems1, target_entities=elems2, tolerance=0.1, result_type=2, review_results=False, ) model.hm_comparefinddistances(max_distance=1.0, review_results=True) _, result = model.hm_comparegetarea(match_type=0, match_location=1) unmatched_source = result.areaPercent print("unmatched_source", unmatched_source) _, result = model.hm_comparegetarea(match_type=0, match_location=2) unmatched_target = result.areaPercent print("unmatched_target", unmatched_target) model.hm_compareend()
