Model.hm_holedetectionfindholes#
Model.hm_holedetectionfindholes(find)#
Runs the hole detection functions for finding holes and tubes based on input entities and parameters. This must be preceded by calls to Model.hm_holedetectioninit(), hm_holedetectionsetentities(), and hm_holedetectionsetholeparams() or hm_holedetectionsettubeparams().
Parameters:
find (int) –
Bit value defining the types of holes and tubes to find (Bit0 + 2*Bit1 + 4*Bit2). Valid Bit options are:
Bit0
Find holes. Valid values are:
0 - Do not find holes
1 - Find holes
Bit1
Find 2D tubes. Valid values are:
0 - Do not find 2D tubes
1 - Find 2D tubes
Bit2
Find 3D tubes. Valid values are:
0 - Do not find 3D tubes
1 - Find 3D tubes
Show Bit value calculator
Radio Button Table
Option Name Value
Find holes (Bit0)
Find 2D tubes (Bit1)
Find 3D tubes (Bit2)
Calculated argument value: 0
Returns:
Example#
Detect holes of any shape in all surfaces in the model and write the hole details shape_type, center, radius, and entities_list to a text file.#
import hm
import hm.entities as ent
model = hm.Model()
with open("C:/temp/holes.txt", "w") as holesfile:
    surf_collection = hm.Collection(model, ent.Surface)
    model.hm_holedetectioninit()
    model.hm_holedetectionsetentities(collection=surf_collection)
    model.hm_holedetectionsetholeparams(hole_shape=31)
    model.hm_holedetectionfindholes(find=1)  # For holes we need to set find=1
    _, result = model.hm_holedetectiongetnumberofholes()
    num_holes = result.numberOfHoles
    if num_holes > 0:
        holesfile.write(f"Number of holes = {num_holes}\n\n")
        for n in range(num_holes):
            holesfile.write(f"Queried data details of hole {n+1}\n")
            _, result = model.hm_holedetectiongetholedetailsdata(
                index=n, query_key="shape_type"
            holesfile.write(f"shape-type = {result.queryValue}\n")
                index=n, query_key="center"
            holesfile.write(f"center = {result.queryValue}\n")
                index=n, query_key="radius"
            holesfile.write(f"radius = {result.queryValue}\n")
                index=n, query_key="entities_list"
            holesfile.write(f"entities_list = {result.queryValue}\n\n")
    else:
        holesfile.write("Holes not detected.\n")
    model.hm_holedetectionend()
    holesfile.close()
