Model.isolateonlyentity_byname#
Model.isolateonlyentity_byname(entity_type, entity_name, showcomps=False, elements_off=False, geometry_off=False)#
Turns on the display of an entity and turns off the display of all others across types.
Parameters:
  • entity_type (EntityFullType) – The type of entity to display.
  • entity_name (hwString) – The name of the entity to display
  • showcomps (bool) – This indicates that components in which elements/geometry are referred will also be shown when you show elements/geometry. If not provided, only specified elements/geometry are shown.
  • elements_off (bool) – This indicates that elements in the specified collectors should not be considered. If not provided, the default is to consider elements in the specified collectors.
  • geometry_off (bool) – This indicates that geometry in the specified collectors should not be considered. If not provided, the default is to consider geometry in the specified collectors.
Examples#
Isolate only geometry and elements for component with name “ MyComponent “#
import hm
import hm.entities as ent
model = hm.Model()
model.isolateonlyentity_byname(entity_type=ent.Component, entity_name="MyComponent")
Isolate only elements for component with name “ MyComponent “#
import hm
model = hm.Model()
entity_type=ent.Component, entity_name="MyComponent", geometry_off=True
