Model.CE_DetailSetDouble#
Model.CE_DetailSetDouble(connector_id, detail_name, double_value, reserved, force_storage)#
Sets a double connector detail for a single connector.
Parameters:
  • connector_id (unsigned int) – The ID of connector to update.
  • detail_name (hwString) –
    The name of the standard double detail, or user-defined double detail, to update. Standard double details include:
    • ce_appliedmass
    The mass value to be applied.
    Value ≥ 0
    • ce_areaconstthickness
    The constant thickness (for area connectors).
    Value ≥ 0
    • ce_aspect
    Fail hexas with aspect ratio greater than this value.
    Value ≥ 0
    • ce_bl_connection_ang
    The maximum angle allowed between two shells for B connection.
    Value ≥ 0
    • ce_bodylen
    The bolt body length.
    Value ≥ 0
    • ce_boltmaxdiameter
    The maximum diameter to be considered a bolt hole.
    Value ≥ 0
    • ce_boltmaxfeatureangle
    The maximum feature angle to identify a solid bolt hole.
    Value ≥ 0
    • ce_boltmindiameter
    The minimum diameter to be considered a bolt hole.
    Value ≥ 0
    • ce_boltminfeatureangle
    The minimum feature angle to identify a solid bolt hole.
    Value ≥ 0
    • ce_boltthread
    The bolt thread length.
    Value ≥ 0
    • ce_centered_quad_pos_tol
    The quad position tolerance.
    Value ≥ 0
    • ce_centered_quad_scale_tol
    The quad scale tolerance.
    Value ≥ 0
    • ce_centered_quad_size_tol
    The quad size tolerance
    Value ≥ 0
    • ce_centered_quad_translate_tol
    The quad translate tolerance.
    Value ≥ 0
    • ce_cylinder_diameter
    Define cylinder using this value as diameter.
    Value ≥ 0
    • ce_cylinder_diameter_factor
    Define the cylinder using this value as a factor.
    Value ≥ 0
    • ce_dia_factor
    The cylinder bolt diameter factor.
    Value ≥ 0
    • ce_diameter
    The diameter required by the realization.
    Value ≥ 0
    • ce_fe_capangle
    The angle between an ending cap element face and shell edge.
    Value ≥ 0
    • ce_fe_const_height
    The hexa constant thickness.
    Value ≥ 0
    • ce_fe_depth
    The penta width.
    Value ≥ 0
    • ce_fe_factor_a
    The hexa thickness, by multiplying this value using the smallest shell thickness.
    Value ≥ 0
    • ce_fe_factor_b
    The hexa position, by adding this value using the half of the thickness.
    Value ≥ 0
    • ce_fe_featureangle
    The feature break angle for locating RBE3 nodes.
    Value ≥ 0
    • ce_fe_hexa_to_washer_offset
    The offset from the hexa boundary to the washer inner diameter.
    Value ≥ 0
    • ce_fe_height
    The quad position in the vertical direction.
    Value ≥ 0
    • ce_fe_maint_gaps
    The gap value between a hexa face and a shell.
    Value ≥ 0
    • ce_fe_offsetangle
    The angle between quad and vertical direction.
    Value ≥ 0
    • ce_fe_rbe3radius
    The radius defining the circular area for locating RBE3 nodes.
    Value ≥ 0
    • ce_fe_runoffangle
    The deviating angle of the quad next to an ending cap element.
    Value ≥ 0
    • ce_fe_tapered_t_angle
    The angle of the tapered T weld.
    Value ≥ 0
    • ce_fe_tapered_t_d
    The thickness of the tapered T weld.
    Value ≥ 0
    • ce_fe_tapered_t_h
    The height of the tapered T weld.
    Value ≥ 0
    • ce_fe_tapered_t_h1
    Value ≥ 0
    • ce_fe_tapered_t_h2
    The width of the tapered T weld.
    Value ≥ 0
    • ce_fe_width
    The penta depth.
    Value ≥ 0
    • ce_hexa_position_distance
    Move hexa by this distance from default position.
    Value ≥ 0
    • ce_jacobian
    Fails hexas with Jacobian less than provided value.
    Value ≥ 0
    • ce_l1
    The cylinder bolt length for L1 direction.
    Value ≥ 0
    • ce_l1d1
    The cylinder bolt diameter for L1 direction.
    Value ≥ 0
    • ce_l2
    The cylinder bolt length for L2 direction.
    Value ≥ 0
    • ce_l2d2
    The cylinder bolt diameter for L2 direction.
    Value ≥ 0
    • ce_lt_connection_ang
    The minimum angle allowed between two shells for T connection.
    Value ≥ 0
    • ce_new_diameter
    The diameter value used for punching a new bolt hole during realization.
    Value ≥ 0
    • ce_no_hole_diameter
    The diameter value when there is no hole during realization.
    Value ≥ 0
    • ce_normal_angle
    The deviation angle allowed for normal projection.
    Value ≥ 0
    • ce_offset
    Line connector end offset value.
    Value ≥ 0
    • ce_quad_size
    The quad size for the quad transition.
    Value ≥ 0
    • ce_seam_break_len
    The break length before the next weld.
    Value ≥ 0
    • ce_seam_elem_len
    The hexa element length.
    Value ≥ 0
    • ce_seam_discontinuity_lower_tol
    The lower bound tolerance allowed by the weld length.
    Value ≥ 0
    • ce_seam_discontinuity_upper_tol
    The upper bound tolerance allowed by the weld length.
    Value ≥ 0
    • ce_seam_weld_len
    The weld length before the next break.
    Value ≥ 0
    • ce_spacing
    The spacing value for a line or seam connector.
    Value ≥ 0
    • ce_tolerance
    The tolerance value specified during connector FE realization.
    Value ≥ 0
    • ce_washer_elem_size
    The element size around a bolt hole.
    Value ≥ 0
    • ce_washer_scale_1
    The 1st washer’s width using a scale of bolt radius.
    Value ≥ 0
    • ce_washer_scale_2
    The 2nd washer’s width using a scale of bolt radius.
    Value ≥ 0
    • ce_washer_width_1
    The 1st washer’s width using this value.
    Value ≥ 0
    • ce_washer_width_2
    The 2nd washer’s width using this value.
    Value ≥ 0
  • double_value (double) – The double value to update for the detail.
  • reserved (unsigned int) – Reserved for future development. Must be set to 0.
  • force_storage (unsigned int) –
    0 - Do not store user-defined detail.
    1 - Store user-defined detail.
Examples#
Set the tolerance to 10.0 for connector with ID 1#
import hm
import hm.entities as ent
model = hm.Model()
model.CE_DetailSetDouble(
    connector_id=1,
    detail_name="ce_tolerance",
    float_value=10.0,
    reserved=0,
    force_storage=0,
Set a user-defined double detail “test” to a value of 5.0 for connector with ID 2#
import hm
model = hm.Model()
    connector_id=2,
    detail_name="test",
    float_value=5.0,
    reserved=0,
    force_storage=1,
