Model.hm_collisionvisualizebymark#
- Model.hm_collisionvisualizebymark(collection, node_collection, review_type, fit_view, display_type)#
Enables the visualization of collision entities using one of various supported visualization modes.
- Parameters:
collection (Collection) – The collection containing the collision entities to be visualized.
node_collection (Collection) –
The collection containing ontaining the secondary node entities from the collision entities on
collection. Only these nodes will be visualized.If empty collection is provided, all colliding nodes/elements will be visualized.
review_type (int) –
A flag that indicates the type of visualization. Valid values are:
1 - Highlight failed elements
2 - Review failed elements
3 - Contour penetration depths
4 - Penetration vectors and intersection lines
5 - Contour relative penetrations
fit_view (bool) –
False- Do not fit viewTrue- Fit viewdisplay_type (int) –
A flag that indicates which elements to display. Valid values are:
1 - Display all elements
2 - Display components with failed elements
3 - Display only failed elements
- Returns:
hwReturnStatus- Status object
Examples#
Highlight intersect elements of components with IDs 1001 and 1002 with auto - fit and display of the components with failed elements#import hm import hm.entities as ent model = hm.Model() _, result = model.hm_collisiongetconfig(options=["intersect_planar"]) config = result.config component_collection = hm.Collection(model, ent.Component, [1001, 1002]) model.collisioncheck2_temp( collection=component_collection, config=config, thickness=0.0, allowable_depth=0.0, tolerance=0.0, pair_angle=0.0, ) collision_collection = hm.Collection(model, ent.Collision) model.hm_collisionvisualizebymark( collection=collision_collection, node_collection=hm.Collection(model, ent.Node, populate=False), review_type=1, fit_view=True, display_type=2, )
Generate a contour plot of penetration depths of components with IDs 1001 and 1002 without auto - fit and display only failed elements#import hm import hm.entities as ent model = hm.Model() _, result = model.hm_collisiongetconfig(options=["collirad", "penetrations"]) config = result.config component_collection = hm.Collection(model, ent.Component, [1001, 1002]) model.collisioncheck2_temp( collection=component_collection, config=config, thickness=0.0, allowable_depth=0.0, tolerance=0.0, pair_angle=0.0, ) collision_collection = hm.Collection(model, ent.Collision) model.hm_collisionvisualizebymark( collection=collision_collection, node_collection=hm.Collection(model, ent.Node, populate=False), review_type=3, fit_view=False, display_type=3, )
