Model.displaycollector#
Model.displaycollector(entity_type, mode, name, elements, geometry)#
Controls the display state of a collector.
Parameters:
  • entity_type (EntityFullType) – Collector types. Valid types for this function are Components, Loadcols, Systcols, Vectorcols.
  • mode (hwString) –
    The mode being performed, defined by the following:
    on - All collectors are turned on.
    all - All collectors are turned on.
    off - All collectors are turned off.
    none - All collectors are turned off.
    toggle - All collectors are toggled (visible become invisible and vice-versa).
    reverse - All collectors are toggled (visible become invisible and vice-versa).
  • name (hwString) – The collector name to be used in the above functions. This parameter may be left blank, if mode is set to “all”, “none”, or “toggle”.
  • elements (int) –
    Indicates if elements within components are to be turned on or off.
    0 - No
    1 - Yes
  • geometry (int) –
    Indicates if geometry within components is to be turned on or off.
    0 - No
    1 - Yes
Example#
Turn the elements and geometry on in the component named “ fender “#
import hm
import hm.entities as ent
model = hm.Model()
model.displaycollector(
    entity_type=ent.Component, mode="on", name="fender", elements=1, geometry=1
