Model.lineextendtonode#
Model.lineextendtonode(line, node, capture_radius, derivative, direction)#
Extends the specified line to a node.
Parameters:
  • line (Entity) – The line entity to extend.
  • node (Entity) – The node entity to which the line is extended.
  • capture_radius (double) – If the point at the end of the extension is within the capture_radius of the node, then force the end point to have the same coordinates as the node.
  • derivative (int) –
    1 - Extend the tangent to the line
    2 - Extend following the curvature of the line
  • direction (int) –
    -1 - Extend the beginning of the line
    1 - Extend the end of the line
Example#
Extend the line with ID 1 to the node with ID 2 with a capture radius of 1.0 . The extend line should be tangent to line and extended from the end of the line .#
import hm
import hm.entities as ent
model = hm.Model()
model.lineextendtonode(
    line=ent.Line(model, 1),
    node=ent.Node(model, 2),
    capture_radius=1.0,
    derivative=1,
    direction=1,
