Model.rigidlinkupdatecalcinodebycollector#
- Model.rigidlinkupdatecalcinodebycollector(element_entity, collection_set, entity_type)#
Updates the rigid link by calculating the independent node based on selection of dependent nodes defined by comps, mats, assems, props sets and nodes.
- Parameters:
element_entity (Entity) – The object describing the rigid element entity.
collection_set (CollectionSet) – The set of collections containing possibly multiple type of entities.
entity_type (EntityFullType) – The type of entity for dependent nodes. Valid entity types are component, material, part, property, set and node.
Example#
Update a rigid link element with ID 7 by select dependent node specified by components with IDs 1 and 2 put on a collection set :#import hm import hm.entities as ent model = hm.Model() # Creating a collection that contains the components component_collection = hm.Collection(model, ent.Component, [1, 2]) # Creating the collection set that contains the collection with the components collection_set_comps = hm.CollectionSet(model) collection_set_comps.set(component_collection) model.rigidlinkupdatecalcinodebycollector( element_entity=ent.Element(model, 7), collection_set=collection_set_comps, entity_type=ent.Component, )
