Model.linemesh_savedata1#
- Model.linemesh_savedata1(create_flag, config, property_id, organize)#
Creates 1D elements and cleans up memory.
Each call to this function must be paired with a previous call to
Model.linemesh_preparedata1()orModel.linemesh_preparenodeslist1().- Parameters:
create_flag (int) –
Flag for generating elements:
0 - Do not generate elements.
1 - Generate elements.
config (int) – The 1D element config ID of the elements to create. If creating bar2 elements (
config=60) the functionModel.linemesh_savedata_bar1()should be used.property_id (int) – The ID of the property to assign to the 1D elements.
organize (int) –
Organizing new 1D elements:
0 - Organize new 1D elements to current component.
1 - Organize new 1D elements to input lines component(s).
Examples#
Mesh lines with IDs 15 and 18 with a 30 degree break angle, creating rigid elements with no property#import hm import hm.entities as ent model = hm.Model() # Creating a collection of line entities which we will # prepare for 1D meshing. line_collection = hm.Collection(model, ent.Line, [15, 18]) model.linemesh_preparedata1(collection=line_collection, break_angle=30.0, config=5) # Assing meshing parameters to line segments for 1D meshing. model.linemesh_saveparameters(segment=0, density=3, bias=0, bias_style=0) model.linemesh_saveparameters(segment=1, density=2, bias=0, bias_style=0) # Creating 1D elements and cleans up memory. model.linemesh_savedata1(create_flag=1, config=5, property_id=0, organize=0)
Mesh between nodes with IDs 16 , 17 , and 2 with 3 rigid elements between nodes with IDs 16 and 17 and with 2 rigid elements between nodes with IDs 17 and 2 , with no property assignment , organize to the input line component(s )#import hm import hm.entities as ent model = hm.Model() # Creating a collection of node entities which we will # prepare for 1D meshing. node_list = [ent.Node(model, 16), ent.Node(model, 17), ent.Node(model, 2)] model.linemesh_preparenodeslist1(list=node_list, config=5) # Assing meshing parameters to line segments for 1D meshing. model.linemesh_saveparameters(segment=0, density=3, bias=0, bias_style=0) model.linemesh_saveparameters(segment=1, density=2, bias=0, bias_style=0) # Creating 1D elements with no property # and using the auto vector, organizing to the input line component(s) model.linemesh_savedata1(create_flag=1, config=5, property_id=0, organize=1)
Mesh between nodes with IDs 16 , 17 , and 2 without create elements#import hm import hm.entities as ent model = hm.Model() # Creating a collection of node entities which we will # prepare for 1D meshing. node_list = [ent.Node(model, 16), ent.Node(model, 17), ent.Node(model, 2)] model.linemesh_preparenodeslist1(list=node_list, config=5) # Creating 1D elements and cleans up memory. model.linemesh_savedata1(create_flag=0, config=5, property_id=0, organize=0)
