Model.CE_MarkUpdateLinkMark#
Model.CE_MarkUpdateLinkMark(collection, search_collection, replace_type, replace_rule, replace_state, string_array, keep_current_state=0)#
Allows search and replace of existing links in the specified connectors with new link information.
Parameters:
  • collection (Collection) – The collection containing the connector entities.
  • search_collection (Collection) – The collection containing the entities to search in the connector. This must be specified. The supported entities are Component, Property, Surface, Tag, Element, Node and Part.
  • replace_type (EntityFullType) –
    If specified with IDs/names/UIDs in the string_array, existing links in search_collection get replaced with the new information. The supported entities are Component, Property, Surface, Tag, Element, Node and Part.
    If specified with no IDs/names/UIDs in the string_array, existing links in search_collection get converted to the replace_type. The supported entities are Component, Property and Part.
  • replace_rule (unsigned int) –
    If specified with IDs/names/UIDs in the string_array, existing links in search_collection get replaced with the new information. If specified with no IDs/names/UIDs in the string_array, existing links in search_collection get converted to the replace_rule.
    The following codes define the different rules:
    0 - Undefined
    1 - None
    2 - Use ID
    3 - Use name
    4 - Proximity
    5 - Use UID
  • replace_state (unsigned int) –
    The flag to set for the link entity that specifies if you are connecting to mesh or to geometry. The supported values are:
    0 - Undefined
    1 - Connect to mesh
    2 - Connect to geometry
  • string_array (hwStringList) –
    A string array containing the list of new IDs/names/UIDs.
    The strings are generally IDs/names/UIDs based on the replace_rule.
  • keep_current_state (unsigned int) –
    Optional option to keep the current connector state after the update operation. Valid states are:
    0 - Unrealize if needed (default)
    1 - Keep current state
    At most, one of the “replace” data must be specified to see a change in the link attributes. If the replace data exactly matches the search data, the connector is not unrealized and no change is made to the link entity.
Examples#
Convert component links with IDs 1-10 to part links across all displayed connectors#
import hm
import hm.entities as ent
model = hm.Model()
connectors = hm.Collection(model, ent.Connector, [1, 2, 4])
components = hm.Collection(model, ent.Component, list(range(1, 11)))
model.CE_MarkUpdateLinkMark(
    collection=connectors,
    search_collection=components,
    replace_type=ent.Part,
    replace_rule=0,
    replace_state=0,
    string_array=None,
Convert link rule for component links with IDs 1-10 to “use-name” across all displayed connectors#
import hm
model = hm.Model()
    replace_type=ent.Component,
    replace_rule=3,
    replace_state=1,
    string_array=None,
Convert component links with IDs 1-10 to “geom” across all displayed connectors#
import hm
model = hm.Model()
    replace_rule=0,
    replace_state=2,
    string_array=None,
Replace component with ID 1 with component group (IDs 2 and 3) across all displayed connectors#
import hm
model = hm.Model()
components = hm.Collection(model, ent.Component, [1])
    replace_rule=2,
    replace_state=0,
    string_array=["2", "3"],
