Model.hm_getsolidshelloverlapinfo#
Model.hm_getsolidshelloverlapinfo(source_collection, target_collection, maxproximitydistance)#
Returns information regarding proximity overlap between one or more solid cavity elements and structural components (2D mesh). For each cavity (source components), the function returns the cavity surface area, the cavity volume, and the proximity overlap area per structural component (target components).
Parameters:
  • source_collection (Collection) – The collection containing the source entities. Currently supported for components entities. Only 3D elements are considered.
  • target_collection (Collection) – The collection containing the target entities. Currently supported for components entities. Only 2D elements are considered.
  • maxproximitydistance (double) – Maximum proximity distance below which the overlap is calculated.
Returns:
  • hwReturnStatus - Status object
  • HmQueryResultList - Result list object containing HmQueryResult objects with the following output data:
    • solidComponent (Entity) - Cavity source entity coming from source_collection
    • solidSurfaceArea (double) - Cavity surface area
    • solidVolume (double) - Cavity volume
    • proximityOverlapArea (HmQueryResultList)-Result list object containing HmQueryResult objects with the following output data:
    • overlapShellComponent (Entity) - Structural component (target entity coming from target_collection)
    • proximityAreaWithSolid (double) - The proximity overlap area per structural component (overlapShellComponent)
Example#
Get overlap information between component with ID 20 and components with ID 2 , 10 , and 13 for a proximity distance of 5.0#
import hm
import hm.entities as ent
model = hm.Model()
source_component_collection = hm.Collection(model, ent.Component, [20])
target_component_collection = hm.Collection(model, ent.Component, [2, 10, 13])
_, resultlist = model.hm_getsolidshelloverlapinfo(
    source_collection=source_component_collection,
    target_collection=target_component_collection,
    maxproximitydistance=5.0,
for result in resultlist:
    print("Cavity:", result.solidComponent.id)
    print("Cavity surface area:", result.solidSurfaceArea)
    print("Cavity volume:", result.solidVolume)
    for overlap in result.proximityOverlapArea:
        print("\tStructural component:", overlap.overlapShellComponent.id)
        print(
            "\tProximity overlap area per structural component:",
            overlap.proximityAreaWithSolid,
