Model.detachelements#
- Model.detachelements(collection, offset)#
Detaches elements as a unit from the attached structure, using the specified offset value.
- Parameters:
collection (Collection) – The collection containing the entities to detach.
offset (double) – The distance by which the elements should be offset from the attached structure.
Example#
Detach element with ID 10 and one layer of adjacent elements from the remainder of the structure#import hm import hm.entities as ent model = hm.Model() # Creating a collection of adjacent elements to the element with ID=10 elem_col_10=hm.Collection(model, ent.Element, [10]) elem_col=hm.CollectionByAdjacent(model, elem_col_10) model.detachallelements(collection=elem_col, offset=0.0)
