Model.organizecomponents#
- Model.organizecomponents(policy, preserve_element_include=False)#
Reorganizes the existing elements by grouping them based on one of the following policies:
By property
Elements of same property are grouped under one component. The component is assigned that property and the component inherits the meta data such as name, color, module, include from the property
By material
Elements of same material are grouped under one component. The component inherits the meta data such as name, color, module, include from the material
As one component
All valid elements are grouped under one component.
By default, the elements follow the components to the destination include which in turn follows the targeted entity (properties or materials). The current element include organization can be preserved using the optional argument
preserve_element_include.- Parameters:
policy (int) –
The grouping policy. Valid values are:
1 - By property
2 - By material
3 - As one component
preserve_element_include (bool) – Optional argument to preserve the current element include structure.
Example#
Organize all components by property#import hm import hm.entities as ent model = hm.Model() model.organizecomponents(policy=1)
