Model.hm_comparegettransformationmatchstate#
- Model.hm_comparegettransformationmatchstate(transformation_index, match_index)#
Returns the state of a specific transformation and match. This must be preceded by a call to a relevant hm_compareentities function.
- Parameters:
transformation_index (int) – The index of the transformation to query, starting with 0. The number of transformations can be found using
Model.hm_comparegettransformationcount().match_index (int) – The index of the match corresponding to the
transformation_indexto query, starting with 0. The number of matches can be found usingModel.hm_comparegettransformationmatchcount().
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:matchState (int) - Possible return values are:
0 - Inactive
1 - Active
Example#
Find the state of transformation 0 and match 5 for the recursive comparison of surfaces with IDs 1 - 20 and 101 - 120#import hm import hm.entities as ent model = hm.Model() surf1 = hm.Collection(model, ent.Surface, list(range(1, 21))) surf2 = hm.Collection(model, ent.Surface, list(range(101, 121))) model.hm_compareinit() model.hm_compareentitiesrecursive( source_surfaces=surf1, target_surfaces=surf2, tolerance=0.1, result_type=2, review_results=False, ) _, result = model.hm_comparegettransformationmatchstate( transformation_index=0, match_index=5 ) match_state = result.matchState print("match_state ", match_state ) model.hm_compareend()
