Model.hm_getfilletfaces_fromcollection#
- Model.hm_getfilletfaces_fromcollection(entities, min_radius, max_radius)#
Returns the faces containing fillets with a radius inside a range.
- Parameters:
entities (Collection) – The collection containing the entities to consider. Valid entities are components and surfaces.
min_radius (double) – The minimum radius value.
max_radius (double) – The maximum radius value.
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:filletSurfaces (EntityList) - Entity Type:
Surface
Example#
Get the faces with fillets with a radius between 5 and 15 only for surfaces in components#import hm import hm.entities as ent model = hm.Model() _, result = model.hm_getfilletfaces_fromcollection( entities=hm.Collection(model, ent.Component), min_radius=5, max_radius=15 ) print("filletSurfaces", result.filletSurfaces)
