Model.solid_fixedptsmaker#
- Model.solid_fixedptsmaker(surf_collection, comp_collection, tol_rel)#
Used in the solidmap panel to create fixed points on the edges of selected components. These points are generated from nodes on the component’s edges that fall within a specified tolerance, and are meant to be transitory.
- Parameters:
surf_collection (Collection) – The collection containing the surface entities. Fixed points are to be made on the edges of these surfaces.
comp_collection (Collection) – The collection containing the component entities. Nodes of the elements in the components of the collecion are considered for making fixed points.
tol_rel (double) – Tolerance relative to the average element size calculated from the elements in the inputted components.
Example#
Create fixed points on the edges of the surface with ID 10 considering nodes and elements from the component with ID 3 with a relative tolerance of 5.0#import hm import hm.entities as ent model = hm.Model() model.solid_fixedptsmaker( surf_collection=hm.Collection(model, ent.Surface, [10]), comp_collection=hm.Collection(model, ent.Component, [3]), tol_rel=5.0, )
