Model.CE_ConnectorAreaCreate#
Model.CE_ConnectorAreaCreate(entitycollection, linkcollection, ent_state, ce_rules, ce_le_rule, tol_flag, tolerance, group, param1, param2)#
Creates area connector(s) at the specific location(s) by collection with certain rules.
Parameters:
  • entitycollection (Collection) – The collection containing the entities to specify the location of area connector(s). Valid entities are elements and surfaces
  • linkcollection (Collection) – The collection containing the entities to be added to the area connector as a link. Valid entities are surfaces and components.
  • ent_state (unsigned int) –
    Specifies whether geometry or element gets precedence during realization of connector. Currently, only element is supported.
    0 - Geometry.
    1 - Element.
  • ce_rules (unsigned int) –
    Rule to specify if and how a link entity is to be added to a connector.
    0 - None.
    1 - Now.
    2 - A fe realize.
  • ce_le_rule (unsigned int) –
    Rule that specifies how an entity is to be remembered by the connector.
    0 - None.
    1 - Use ID.
    2 - Use name.
  • tol_flag (unsigned int) –
    Specifies if tolerance value is applicable.
    0 - Use default.
    1 - Use specified value.
  • tolerance (double) – Specified to add entities only with in the given tolerance from the specified connector.
  • group (int) –
    Specified if do group after creation.
    0 - Do not group.
    1 - Group.
  • param1 (int) – Reserved for future development.
  • param2 (double) – Reserved for future development.
Example#
Create 2 area connector at elements with IDs 1, 2, 3, 6, 7, 8 and add nearest 2 of the four components specified within a tolerance of 1.0, remembers the components by their IDs, and does not group connectors after creation#
import hm
import hm.entities as ent
model = hm.Model()
model.CE_ConnectorAreaCreate(
  entitycollection=hm.Collection(model, ent.Element, [1, 2, 3, 6, 7, 8]),
  linkcollection=hm.Collection(model, ent.Component, [21, 23, 24, 27]),
  ent_state=1,
  ce_rules=1,
  ce_le_rule=1,
  tol_flag=1,
  tolerance=1.0,
  group=0,
  param1=0,
  param2=0.0,
Note
Each created area connector displays as a plane with cylinders located at the corners, and only the closest two components are added to it. The total number of layers defined at each area connector is 2.
